SOURCE: Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Testimonial: "Problem solved!"
Don't you "fix ya" guys make enough money from all the ads on your site? Why must you deviously draw me in with the promise of a free solution and WASTE MY VALUABLE TIME when you never had ANY intention of doing what you say? Where I grew up you would be in for a beating if you were man enough to be present with your weak ****!!!
