GE WWSE5200B Top Load Washer Logo
Posted on Aug 10, 2011
I have GE top load washing machine wwse3160aoww. it is dead set and i found out a burnt PCB of the main program timer and control board. what could be possibly be wrong. i can replace the control board but could end up damaging the new one if there is a serious problem coming fron the components inside the machine. please help?
5 Related Answers
A
Anonymous
  • Posted on Jan 25, 2008
SOURCE: GE frontloader door gasket ripped
We had the same problem. We only washed clothes in it like 3 times and we had water all over our brand new built house. Luckily the store we bought it from brought us a new machine. I refused having them fix it after water ran all inside the machine. Now I have a problem with the washer EATING our clothes up. Lost a packer jersey and 3 pairs of pants!! I'd never buy one again.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 28, 2008
SOURCE: GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Anonymous
  • Posted on Mar 02, 2009
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Anonymous
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Anonymous
  • 512 Answers
  • Posted on Aug 18, 2009
SOURCE: water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Frigidaire Laundry center replace central board and washing selector board but it's not working.
For that many issues and for the amount of money you spent, you need to call out a technician who knows this machine. Sometimes, you just have to let the pros take over. Burnt cables is never a good sign as it can take everything with it.
1helpful
How does a PCB main assembly look like on a LG washing machine
pcb board main is the one thats accessed though the back of the washer behind the panel, the unit is usually at the bottom left side and has loads of wire and plus on it, it controls the motors and the heating element when told by the cyle board, it has switch-relays that turn things on at the times set for the setting you you to wash your items.
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
1helpful
Error message on wpgt9350c0pl washing machine
HI. the Main Pwb/pcb assembly(board) must be replaced in this case. there is a chip set failure that has occurred. The main board is inoperable at this time.
My washer will stay on for a few minits then it turns off i have to unplug it and wait a while then it works again for a few minits
Hi, this is a typical timer or , control board issue. the control sector is damaged. possibly a circuit malfunction or, a damaged chip set. replacing the timer control or, control board will fix this issue.
Timer and washer will fill water to level but will not wash
HI, if the timer is not functioning, this is caused be a main control board chip set failure. you will need to replace the main control timer/control in this unit.
The timer/control initiates all the wash commands and, if it malfunctioning, it will cause these symptoms you are experiencing at this time..
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
