Panasonic Toughbook CF-73 Notebook Logo
Posted on Aug 10, 2011
My laptop model is Panasonic CF-W4. When i turned on laptop it shows a msg {Standard RAM Failed (01-80)}. It shows everything fine in bios n it shows 256 Mb RAM in bios. Ram is permanently fixed in this model, i cant replace it. What is problem ? Please help me....????
5 Related Answers
Anonymous
  • 3587 Answers
  • Posted on May 04, 2008
SOURCE: What is max ram for CF-73ECLTXKM
www.panasonic.com has that information for you
mail2pvs
Pavan Ponangi
  • 390 Answers
  • Posted on Jul 12, 2009
SOURCE: Standard RAM Failure after extended RAM replacement
hi
there are two hings to be noted here
1. the toughbook supports DDR2 SDRAM check to see if u have the right thing installed
2. the toughbook is expandable to 1536MB roughly1.5GB while you have put in 2GB and the possibilities are it is thus rejecting
try taking off the expanded ram chips and if it works then try expanding to 1.5GB (meaning add only one 512 RAM Chip) first and then check
cheers
pls rate if this was any help
tom walsh
  • 228 Answers
  • Posted on Dec 22, 2009
SOURCE: I WANT TO CHANGE MY HDD 80GB AND 512 MB RAM
Go to Crucial or Viking or any memory company on the web, type in your model number, and they will provide the proper memory module advice. You can remove the cover from the HDD on the bottom of the toughbook, and inspect the current disk to determine if it is SATA or not. I would check the manufacturer and series (model) and see if they had a larger in the same series. It will be labeled if it is SATA or EIDE, and you would get the same in a larger internal size.
tom
Anonymous
  • 763 Answers
  • Posted on Jan 07, 2010
SOURCE: After adding 256 MB with existing 256 MB showing
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
emallari27
Erni Mallari
  • 94 Answers
  • Posted on Feb 03, 2010
SOURCE: I have a Fujitsu Lifebook E2010 with one 256 MB
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
2answers
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • 0helpful
    Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
    According to Panasonic's Toughbook CFT8
    owners manual there is only one slot where
    you can add extra RAM. The other memory
    is "non-removable" and probably soldered
    directly to the motherboard.
    I double checked on the Kingston RAM Website:
    Bank Schema: 1GB Standard:
    [1GB] (Non-Removable)
    or
    3GB Standard:
    or
    2GB Standard:
    [2GB] (Non-Removable)
    or
    3GB Standard:
    Sorry to disappoint you but that is how they
    made the CFT8 Toughbook.
    If it is any consolation, the CFC1 and CFC2 both have
    two (2) slots on the underside of the unit. Not the CFT8.
    Good Luck,
    Regards,
    Richard - Montreal Based
    Panasonic Canada Toughbook Authorized Dealer since 1989
    Put panasonic cf 29 into safe mode
    On ALL Panasonic Toughbooks you can
    boot into safe mode as follows:
    Make sure the Toughbook is OFF.
    Power on the Toughbook and immediately
    start to press repeatedly the "F8" function key
    which is usually located above the number 7 key.
    You only have 2-3 seconds to do this and this
    will only work in Windows XP, Vista or Windows 7.
    A "text-only" screen will come up. You can then
    choose SAFE MODE or if you also need to
    connect to the internet choose:
    Safe Mode with Networking.
    Use the UP or Down Arrows to highlight the
    selected option and then press Enter.
    That is it.
    Good Luck!
    Regards,
    Turn on backlit keyboard
    The backlit keyboard on the CF-U1 is set to on by default from the factory. To turn the backlight on and off the key combination is Fn + Z.
    Please note the keyboard icon printed under the Z key.
    2helpful
    Audio sounds sotware panasonic cf-w4
    You can download the all the drivers from here
    http://pc-dl.panasonic.co.jp/dl/search?q=panasonic+CF-W4&button=&dc[]=002001&p1=&p2=&oc=&lang=
    Thanks & Regards,
    JJ
    2helpful
    3answers
    Installed Ram, now wont boot with the new ram? Put old Ram, starts fine?
    The new RAM is either faulty or incompatible (not the correct type).
    For larger RAM use the same make and type as the old RAM
    1helpful
    2 beeps no display model cf-27eb
    This POST error could mean BIOS error or a system board failure.
    I suggest you replace the BIOS battery and configure the BIOS date and time etc. If this doesn't work then reseat the RAM modules.
    If this doesn't work, take the RAM module/s to youe friendly computer shop to get them to test the RAM.
    If all this fails then most likely the laptop's motherboard is dead.
    Panasonic cf-50
    go to panasonic.com and download a bios update to a floopy then turn on your comp hit f2 to bring up your configs select boot then boot from floppy then restart your comp
    Panasonic cf-x1w laptop model
    This means it's a laptop sold in Japan and I'm pretty sure there isn't anything you can do about it. If they made a unit with identical hardware and sold it in the US under a different model # than you can d/l the bios update for the US model and flash it over the Japanese bios. Call the manufacturer to see if that is the case.
    Top Panasonic Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
