Hi,try default code "0000" or "1234" and if it does not work then try
unlocking4free to get master reset code for your mobile by just
submitting your mobile's imei number and get reset code to reset your
mobile..
Hi, - To unlock you samsung gt c 3530 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password. - The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
If you forgot the security code for your mobile , get the master reset code here, recently i had a experience with this site unlocking4free & i got the mater reset code , it provides at free cost & very good in services..
You can Unlock the Nokia From the Security Lock/Password Lock using the Master Reset Code,,,You can Check Master Reset Code for your Model mobile...at http://www.prounlocking.com/unlocking-services/rs8wp6/ there You can get the Mater Reset Code at reliable cost.. I unlocked my Nokia 6030 From Security Lock there.
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
