hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
The memory elements on the PCB are not connected, have poor contact, or are faulty. Description 0001 An error has occurred in the course of a read/write check of the memory on the IP memory PCB. 0002 An error has occurred in the course of a read/write check of the memory on the ED board.
Try to reconnect all conectors on dc controller pcb.
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise. If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one. 120V: FH3-2613 220V/240V: FH3-2614 The circuit has been modified to resist a noise.
REMEDY
Caution Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty. For the reset : COPIER-FUNCTION-CLEAR-ERR.
