SOURCE: Issue with imate JAQ
Dear Have u got ur GPRS or EDGE service activated from AIRTEL. Pls confirm it, if yes then following are the settings for airtel.
go to
>>START>>SETTINGS>>CONNECTIONS
connections>>Add a new Modem connection
>>Enter name-airtel or Mobile office
>>select a modem>>it should be Cellularline (GPRS)
>>NEXT
>>eNTER THE NAME AS IT SHOULD BE DIALED
>>enter airtelgprs.com (all small caps)
>>NEXT
>>FINISH
NOW again go to START>>SETTINGS>>CONNECTIONS>>connection>> Advanced>> select networks
There will be two options
1-prog that automatically connect to the internet
2-prog that automatically connect to a private network
>> for both options select >>My ISP
>>tab OK
SOURCE: I NEED TO CONNECT MY I MATE K JAM WITH MY LAP TOP
connect to computer then the popup comes up and search there and it comes up!
SOURCE: I M USING I-MATE JAQ3...I
Here is the information I found for you concerning how to get wireless on your I-Mate
The well-connected JAQ3 has both WiFi 802.11b/g and Bluetooth 1.2. You'll manage these using i-mate's Wireless Manager (accessible by tapping the strength meter on the Today Screen taskbar). WiFi supports the faster g standard and the device will connect to routers running in "g only" mode. Unfortunately, in our speed tests the JAQ3 got slow results when browsing over an 802.11g connection and DSL Reports speed tests showed an average of 340k which isn't as good as 3G and EVDO in many areas. In contrast, we get up to 1250kbit/s with the T-Mobile Dash and 1500kbit/s with the HTC TyTN over WiFi using the same router and speed test. I-mate includes a WLAN monitoring application that provides current connection information including SSID, channel, Tx rate, MAC address, signal strength and it allows you to set power savings as well as WiFi radio timeout.
The JAQ3's Bluetooth 1.2 radio uses Microsoft's basic Bluetooth software and stack. It supports a wide range of profiles including A2DP (stereo audio), AVRC (AV Remote Control, using for controls on Bluetooth stereo headsets), hands-free, HID (keyboards and mice), BIP (printing over Bluetooth), SAP, serial port, object push, DUN and ActiveSync. Nice! We tested DUN and it worked well. Headsets were another matter, with relatively poor range with our selection of headsets including the Scala-700 and Samsung WEP200. Audio quality wasn't the best either with minor drops in audio and echo on the caller's end.
SOURCE: I CANT CONNECT TO MY WIFI NETWORK
Here is the information I found for you on how to connect to wireless:
