Question about RCA HD52W59 HDTV Projection Television
How do you remove the 150 114 120 capacitors do you just pull them out,do they need to be sodered,i have new ones and i'm not sure how to replace the new ones
    President:
  • 1,284 Answers
If they are the surface mount capacitors, you have to heat up each end and use a solder wick. Be careful as you don't want to heat up the components near the caps you are replacing. The surface mount components have a dab of paste to attach them to the board during manufacturing that holds them in place until they are soldered by a machine. Once you remove the solder on both ends you need to use a pair of long handeled tweezers to actuallt grip the componen, heat up rapidly both sides while slightly twisting the component, but being very careful as to not destroying the printed circuit traces. Its best to use a magnifying lamp to look through while doing this process. Good luck : )
Posted on Aug 11, 2011
6ya staff
SOURCE:
How do I get the engine to idle down?
Have you tried disconnecting the battery and touching the two cabled together. Why did you replace the capacitor?
Dec 27, 2014 | Cars & Trucks
Standby power failure
If warrantee still good get new one if not check for broken solder joint on transistor works until it gets hot may need new transistor should have numbers on it., If to hot will need schematic. first get sodering iron and soder 60/40 remove all covers, get(freeze it) a can of cold spray and keep hands away from power supply board the board with the wall plug coming out of it and the thick wires connected to it. do not touch, Plug it in the wall and wait until it turns off, spray the componets that you think are the problem the cold will allow it to turn on for a while check the transistors first (little black box with three leggs) then the capacitors (the little blue barrels with the black lines on them) when you find the componet call the company for the replacement part find the manufacturing company on the internet they will have it.simply make a drawing of the way the componet was in the curcuit and put the new one in,tip on how to soder pull the soder off the roll about five inches, Place the hot tip on the leg and the board wait a second and drop the soder on the hot tip for just one more second, letting a small amount melt off.do this on each leg remember that a transistor has a ground,a hot, and a base,The cap has only a positive and a negative.Good luck
Aug 26, 2012 | Denon AVR-2308 AV RECEIVER 220 Volts-19407
Red light blinks 7 times
Hello Its a common problem of LCD television.The cause that symptom is a faulty power supply. There's a leak capacitor in the power supply that my cause of abnormal output voltage supply.If you want to try repair or fix your television this are the procedure,you can identify the leak capacitor through visual checking.The bad or leak capacitor have bulging top compare to flated top of good capacitor.Just try to open the cover of the TV and look the power supply pull out and remove the cover of power supply and you can see the bulging top of capacitor.Replace new capacitor with the same value,Avoid short circuit when you sodering the PCB board of the power supply.If you can't do the repair,call a technician of sent it to authorized service center.Thank you hope it will help you...
Aug 30, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do you remove the 150 114 120 capacitors hdtv do you just pull them out,do they need to be sodered,i have new ones and i'm not sure how to replace the new ones the tv's green light comes on...
Thanks for asking and trust our experience on Fix ya.
Normally we use a solder wick or special extractor to remove the solder. Sorry to tell you something that may confuse you, but there are several things you need to know before removing the capacitors. As the position of polarity, positive and negative terminals, be careful not damage electronic driving tracks, you should not leave any residual solder on the board. You can do it!, But be careful and calm doing it. I wish you luck, and let me know as it turned out your first job in electronics. Thank you for visiting fix ya!.
Aug 10, 2011 | RCA HD52W59 HDTV Projection Television
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
What could cause a Philips M # 47PFL3603D/27 to start smoking?
maybe it was hanging out with the wrong crowd... just kidding.. The only way to find out is to open up the tv. Unless the smoke was coming from near the power cord. When you open up the tv, there will probably be some sort of burn mark on the circuit board where a capacitor may have blown. If this is the case (and provided that the circuit board wasn't damaged too badly, you can get a sodering gun, remove the blown capacitor(s) and see if you can find replacements at your local electronics store and then soder it back in. If not, you might need a whole new circuit board.
Mar 15, 2011 | Televison & Video
Tv dosent have any video it only has audio no
you have bad capacitor in circuit board.
www.youtube.com search for , plasma tv capacitor repair. video's on how to tell a bad capacitor and also how to replace one will pop up . 15 to 35 dollar fix with a sodering iron and some soder ( and capacitors) you will be watching nfl in no time
Feb 26, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
Apex tv converter box won't turn on.
what can my customer do to get his remote to work? red light on but no green light.
Jun 20, 2009 | Apex Digital HT-150 System
Soyo monitor goes dark every few minutes.
take it a part and look for swelled capacitors take out the bad ones and soder new ones in and then its back on
Jan 13, 2009 | Soyo DYLM24D6 LCD Monitor
Monitor light blinking
Some monitors blink 2 different collers and that means that their is no video signal and some monitors will blink real fast.This is caused by a power cap going bad.If this is happening you need to take appart the monitor and look for a power cap that has stuff leaking out of it or one that has a loose connection to the board or one that is bubeling on the top the power cap.The top of the power cap should be extremly flat.(here is the problem their could be a bad power cap and it might not be showing any signs of going bad).You will need to replace the cap.You can go to radio shack or fry's and they will usually have the parts for cheep.You will need to know the voltage and the pecofarrets.The voltage and the pecofarrets are usually listed on the cap.For example 350 voltage and Fu 4.5 (Fu standing for pecofarrets).You will need to remove the old power caps by applying heat with a soder gun to the under side of the board.Make sure you know which prong on the power cap is positive and which is negitive as the cap is polarity concious.(usually on the doard under the cap it will say + or -.The longest prong on the new cap will be positive).Once you have identified the bad cap or just replaced and removed them all you will need to use a soder gun and soder to atach the new power caps to the board.After sodering cut any acess langth of the prongs off and reasemble the monitor.Now hopfully the monitor works.
Oct 11, 2007 | LG Flatron 563LE 15.1" LCD Monitor
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
