Question about RCA HD52W59 HDTV Projection Television
How do you remove the 150 114 120 capacitors hdtv do you just pull them out,do they need to be sodered,i have new ones and i'm not sure how to replace the new ones the tv's green light comes on and then it shut rihgt off in 5 seconds and there's no picture or sound
  • Chris Hill Aug 11, 2011
    i never even thought of that , well norman you're the MAN ! you're a life saver. god bless
    Champion:
  • 230 Answers
Thanks for asking and trust our experience on Fix ya.
Normally we use a solder wick or special extractor to remove the solder. Sorry to tell you something that may confuse you, but there are several things you need to know before removing the capacitors. As the position of polarity, positive and negative terminals, be careful not damage electronic driving tracks, you should not leave any residual solder on the board. You can do it!, But be careful and calm doing it. I wish you luck, and let me know as it turned out your first job in electronics. Thank you for visiting fix ya!.
Posted on Aug 10, 2011
  • Chris Hill Aug 10, 2011
    thank alot noe i really appreciate your response it's very helpful to know. yeah i'm gonna be real careful doing this , i'll let you know how it turns out . have a great day !!
  • 1,591 Answers
If you google "how to solder" and "how to desolder" or "how to de-solder" in the VIDEOS category, you should be able to find many videos that will show you how to perform this task. It's much better to see it done than to try to follow a description in text!
  • 760 Answers
You cannot just pull capacitors out. First you need a soldering iron, some solder wick and some solder resin. Turn the board over and with your wick and iron remove the solder from the legs of the capacitor being careful not to break the pad of the board. Once the solder is removed you can safely pull the bad capacitor out and slide the new capacitor in. Very important that you match the marking on the board with the marking on the capacitor. Once the capacitor is in, dab a little solder resin to the legs and the board. Now you can apply your fresh solder. Cut the legs down and you are done. Good luck to you.
Posted on Aug 11, 2011
    President:
  • 1,654 Answers
They have to unsoldered and resoldered, juts pulling them out will result in a broken board or pin and the board will be unusable if it is damaged.
    thanks david thats what i kinda thought.
  • Dcramer531
    Dcramer531 Aug 12, 2011
    I Apoligize I didn't go into any more detail, most of the time I get a question like this and the person never even looks at it and I wasted my time and I now realize I should have spent more time detailing the process for you. If you have any other questions or issue please feel free to ask.
    Thanks.
6ya staff
SOURCE:
Standby power failure
If warrantee still good get new one if not check for broken solder joint on transistor works until it gets hot may need new transistor should have numbers on it., If to hot will need schematic. first get sodering iron and soder 60/40 remove all covers, get(freeze it) a can of cold spray and keep hands away from power supply board the board with the wall plug coming out of it and the thick wires connected to it. do not touch, Plug it in the wall and wait until it turns off, spray the componets that you think are the problem the cold will allow it to turn on for a while check the transistors first (little black box with three leggs) then the capacitors (the little blue barrels with the black lines on them) when you find the componet call the company for the replacement part find the manufacturing company on the internet they will have it.simply make a drawing of the way the componet was in the curcuit and put the new one in,tip on how to soder pull the soder off the roll about five inches, Place the hot tip on the leg and the board wait a second and drop the soder on the hot tip for just one more second, letting a small amount melt off.do this on each leg remember that a transistor has a ground,a hot, and a base,The cap has only a positive and a negative.Good luck
Aug 26, 2012 | Denon AVR-2308 AV RECEIVER 220 Volts-19407
TV Toshiba flat screen
You hv bad capacetor on power board. Just open back of your tv and you will see couple capcetor swelen. They are only couple of dollar each. You just need to know to soder them
Jul 05, 2012 | Toshiba 46SL412U 46 Class Widescreen LED...
Red light blinks 7 times
Hello Its a common problem of LCD television.The cause that symptom is a faulty power supply. There's a leak capacitor in the power supply that my cause of abnormal output voltage supply.If you want to try repair or fix your television this are the procedure,you can identify the leak capacitor through visual checking.The bad or leak capacitor have bulging top compare to flated top of good capacitor.Just try to open the cover of the TV and look the power supply pull out and remove the cover of power supply and you can see the bulging top of capacitor.Replace new capacitor with the same value,Avoid short circuit when you sodering the PCB board of the power supply.If you can't do the repair,call a technician of sent it to authorized service center.Thank you hope it will help you...
Aug 30, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
What could cause a Philips M # 47PFL3603D/27 to start smoking?
maybe it was hanging out with the wrong crowd... just kidding.. The only way to find out is to open up the tv. Unless the smoke was coming from near the power cord. When you open up the tv, there will probably be some sort of burn mark on the circuit board where a capacitor may have blown. If this is the case (and provided that the circuit board wasn't damaged too badly, you can get a sodering gun, remove the blown capacitor(s) and see if you can find replacements at your local electronics store and then soder it back in. If not, you might need a whole new circuit board.
Mar 15, 2011 | Televison & Video
When power button is pressed,click,click,click then comes on some of the time. then plays fine. this is with the back off. i removed the power supply board and checked for bad soder joints.lookes good.
Check all the capaciotors in the power supply board for bulges up or little puffs up.Change these capacitors will get ur power back to normal funsctions.
Apr 24, 2010 | Philips 42FD9954 42 in. Plasma HDTV
No picture & no sound
Hello,Ok the procedure is a follows:1) get the service manual of the TV (to aid you in taking out the Circuit board in the proper fashion)2) after you remove the board use a soldering iron and a desoldering pump to remove the solder on the foil side of the circuitboard.3) pull the capacitors out slowly, and replace them with the new ones making sure to put them in correctly.4) solder the new capacitors in, and make sure you did not short any of the circuit traces together.5) Reinstall the board, according to the service manual instructions.6) test the TV by trying to turn it on.7) if all is ok finish the reinstallation procedure and put the back cover on and test the TV one more time.That's the procedure.The reason you need the service manual is because there are differences in how to remove boards between models of TVs and it's best to do the job according to the specifications.Thank you,I hope this helpsShuttle83http://www.electron-age-technologies-llc.com
Jun 09, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Lcd tv .red light flashes repeatedly but no picture or sound
That usually indicates power failure some where on the circuite board. If you heard a ' POP" a capacitor probably blew out.
If you knew enough to repair it your self, then you wouldnt be asking and if you dont, then you should take it in for repair by a shop, unless its a cheap t.v., in which case, buy a new one.
You would need to locate what poped and try to obtain a replacement part, then soder it onto the board after removing the bad part.
If you dont know what your doing you could shock or kill yourself, start a fire or damage the T.V. further.
The cost for repair may be as much as buying a new HDTV so be sure you know what its going to cost before dishing out cash to a repair shop.
Good luck
Feb 01, 2009 | Computers & Internet
Soyo monitor goes dark every few minutes.
take it a part and look for swelled capacitors take out the bad ones and soder new ones in and then its back on
Jan 13, 2009 | Soyo DYLM24D6 LCD Monitor
Hd150lpw175
You have to unsolder the old capacitors and then solder in the new capacitors. You have to make sure to observe the correct polarity and install the new ones the same way as the old ones one side is marked negative dont mix them up do one at a time and notice which side is marked negative on the old one and install the new one the same way. also make sure they have the same uf ratings as the old ones.
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD52W59 HDTV Projection Television Logo
292 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
