THE BUCKET FULL LIGHT STAYS ON AFTER EMPTY BUCET IS REPLACED; ALSO THE HUMIDITY led READS O1. IF i UNPLUG AND PLUG BACK IN IT RUNS FOR LESS THAT 5 SECONDS AND SHUTS OFF. THIS UNIT IS ONLY A YEAR OLD PURCHASED AT HOME DEPOT LAST SUMMER
The switch may not be the problem. However, a dirty or clogged air intake filter or the humidity extraction level set to high could be.
Turn the unit OFF & unplug it. Remove and clean the air intake filter thoroughly. Be sure the filter is completely dry, before reinstalling. Never operate the unit without the filter in place.
After the filter is dry, reinstall it, plug the unit and turn it ON. Lower the humidity extraction level to 35%. If you have an analog unit (No LED screen) set the humidity extraction knob on Maximum.
And finally, be sure that the water collection bucket is installed properly and is not vibrating loose when the unit runs. It should fit squarely into it's holder, making contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly, it should not tilt down at the bottom of the bucket.
All of the above should solve the problem and you won't need to purchase a new switch. But, in the unlikely event, that you will have to. You will need to furnish the Brand Name of the unit and the Correct Model Number. As, they are not all the same.
Hope this helped you and thanks for choosing FixYa.
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Assuming you have already emptied the bucket (?), the bucket may not have been reinstalled properly. When this happens, you get what you described. Turn the unit OFF & unplug it. Remove the water collection bucket an reinstall it, so the it fits "squarely" into the bucket holder from top to bottom. It needs to make firm contact with the bucket removal safety switch on the left rear wall of the bucket holder. The bucket should not tilt down at the bottom when installed properly. Plug the cord back in and turn the unit ON. Set the humidity extraction level to 35%. If installed properly, the unit should turn ON within 5 seconds.
If the above does not solve the problem, the bucket safety removal switch may be broken. Remove the bucket and try activating it with your finger while the bucket is removed. If the unit doesn't start within a fem seconds, the switch is bad and should be replaced.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
This
usually happens when either the Float Valve in the bucket is stuck in
the UP position (if yours is so equipped. Jiggle it to get it to return
to the DOWN position.
If you humidifier's bucket is not so
equipped. It's usually an indication that the bucket was not
reinstalled properly, after it was removed. To check and correct this,
turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the
bucket and reinsert it, making sure that it fits "squarely" in the
bucket holder from Top to Bottom. Once installed, make sure the bottom
of the bucket is not tilted down in any way. Plug the unit back in and
turn the Master ON/OFF Switch to ON. If it was reinstalled correctly,
the bucket full light should have gone off and the unit will run as it
should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
