Maytag EPIC MFW9700S Front Load Washer Logo
Posted on Aug 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We just got a 2 year old Maytag Epic Z washer/dryer set. The washer will not fill hot water. If a cold water cycle is run- it washes fine. If a warm water cycle is run, it will start to fill, and then F20 error out approximately 10 minutes into the cycle. If a hot water cycle is started, it doesn't even pretend to fill- it just sits silently for 6 minutes and then F20 errors out. When the "Pause/Cancel" button is pushed after the F20 error on the warm cycle, water is discharged from the hose, on the hot cycle- nothing. The hot water is on, the hose is not kinked, there does not appear to be anything plugging the inlet screen, nor plugging the hose- if the hose is disconnected from the washer and the water is turned on- water flows fine from the hose. The washer has been shut off by the "Pause/Cancel" button, and it has had the power removed for several minutes. I have NOT removed power during the F20 error.
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 13, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10837901
Points
101584
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
1helpful
Maytag Epic Z Washer F-20, Water Inlet replaced, still F-20 Error
Chris an F-20 is usually a clogged filter on duet washers. Did you go by the tech sheet in your machine? It gives the codes and remedys and is in a jacket behind the kickplate which you remove to get to the filter. You will need a quarter inch nutdriver to gain access.
SERVICE MANUAL is HERE on my manual page
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
My Maytag clothes washer won't fill with hot water
Then you most likely have a bad hot water valve. On Maytags the valve is one combo unit for both hot and cold. Maytag didn't change that much for a number of years, so you may be able to salvage one out of an old machine somewhere and fit it in -- that's what I did when my wife's Maytag did this.
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at [email protected] Catriver..post back.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
