Need to close the plotter door on the 5309L Gestetner. Where do I find it? Also on another gestetner, same kind when you hit start it says IDLE and will not run. What does that mean. Help please.
E - 22 Scanner home position sensor error.Possible causes: scanner home position sensor failure scanner motor defective incorrect scanner ddrive wire position Remove the exposure glass and verify the wire and the sensor actuator. Turn DIP switch 101 - 1 ON and press START key to run free the scanner.DIP switch is located on PWB board in rear area,remove the rear cover.
if you search google for the plotter model and it will let you download a windows 7 driver cos i just looked and there is one, try this: http://www.driverplatform.com/file_a045.html
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
I believe that model is fairly old.... Dosen't the control pannel have a red light showing what door or cover is opened??? Try all the doors and covers and look in the last spot you pulled a paper jam from...
Is this a wide format copier?
