Hi Error
code LE indicates that either the motor is not turning or has locked up for
some reason. It can also be due to Hall sensor which monitors direction and
speed of the motor. If the sensor is faulty then also this error appears. Motor
lock can be caused by several things from a loose connector, to a bad motor. To
make sure it's not a locked motor, try turning the drum with your hand. And, if
there is any resistance while turning the drum or the drum doesn't move freely
then the motor is locked and you'll need to get it replaced. If the motor seems
to be fine then you would need to replace the Hall Sensor. To replace the hall
sensor, take the back cover off. Take the big nut off and remove the motor
rotor. Remove the bolts holding the motor windings. Remove the electric plug on
the sensor and unclip it from the motor winding. Hope this
helps...please post back for further assistance. Daniel
