SOURCE: Kodak AiO home center software
I persisted in finding a solution with the help of Kodak but the solution was that the scanner was flawed and the printer is being replaced - AGAIN. The first tech I talked with was clueless and absolutely no help. The second person went through some steps with me and determined, once again, there is a flaw in the printer -- the 3rd replacement. The first printer had a print-head problem out of the box, so it was returned to the store & exchanged for another. The replacement worked for some 3 months without a hitch and then stopped working - just would not print, but the scanner worked. So I just rec'd my Kodak ESP-3 number 3 on Tuesday this week. Printer worked, scanner didn't. Now I am waiting for my 4th replacement. It is ridiculous, but when it does work, it is a nice little printer -- quality of photo printing is great, and you can't beat the cost of the ink refills. And so it goes.
SOURCE: my kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
SOURCE: My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
SOURCE: my kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
SOURCE: My Kodak ESP 3250 won't
Try initiating the scan from the computer, once you plug in the USB cable into your computer, go to My Computer, right click the sanner (should be called something along the lines of KODAK ESP.....) and press scan, then click which program you'll use to scan it, I usually do the Microsoft one, Good luck!!
1. Browse to Start
-> Run... and type in "NET STOP SPOOLER" (this will stop the print
spooler service)
2. Browse to your
windows\system32\spool\PRINTERS\ folder. You should see
files there ending in .SPL and .SHD created around the time you tried to print
- delete these files.
3. Browse to Start
-> Run... and type in "NET START SPOOLER" (this will restart the
print spooler service)
Double click the
printer icon in the lower-right corner of your taskbar to examine your print
job queue and browse to View -> Refresh.
Reboot your computer. Then, try to scan again.
