SOURCE: KM-3035 scanning issues
Are you a tech? Do you have the scanner utility installed and running? Do you have the windows firewall on? Do you have some other virus software on? The scanner utility has to be in the exception list. It uses port 139 and it has to be enabled.
Can you pull up the scanner web page? When you set up the scanner utility, you have to create a scanner file destination.
It has to match the destination on the 3035 scan directory.
Or it will say,"unable to find destination". Do you have address book installed? you have to have it on at least one computer?
SOURCE: No way to cancel print job
If I have to cancel something I hold down the orange button until the printer is completely silent. If I am desperate I just turn it off. It has always worked for me - not sure if it is the right way to do things or not :)
SOURCE: unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
SOURCE: What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
