Youtube can save LOT of bandwidth: here's how: when i go to any video, play it for some time(say 4 minutes) and then go to fullscreen mode, and watch it for a minute, and then press the "X" button to restore the original video size, it starts to download video content that had already been downloaded (when video was in fullscreen mode) as shown by the red progress bar of the video, which is a waste of youtube server bandwidth and user's computer bandwidth.
Optic Sensor MOTOR Signal Test Procedure
Turn on unit power. Do not press display keys. Use your hand to rotate the motor flywheel. Normal result:
LED 10 lights to indicate the optic sensor signal entering the drive board. The LED appears to flicker at a
low speed and remain lit at high speed.
Optic Sensor MOTOR Signal Test Results
If LED10 does not light, inspect:
1. Optic sensor signal wires and their connections; Reinsert wire ends into connectors.
2. Whether optic sensor wheel rotates in the middle of the sensor; If not, reinstall the optic sensor wheel.
3. Whether optic sensor wheel teeth are broken or bent; if so, replace the optic sensor wheel.
4. If LED2, the VCC circuit indicator, on the drive board lights and there is no optic sensor signal output
(LED10 does not light), and if optic sensor wires and connections are good, replace the optic sensor. Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Test the transformer: tips how to measure the transformer replace the drive board if the transforme is o.k
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Some consoles require batteries. Check to see if this is the problem. If the console does not use batteries, move on to Step 2.
Remove the key from the console.
Unplug the power cord.
Remove the screws from the console hood and remove the hood.
Turn the pulley until the reed switch and magnet are aligned with a 1/8-inch gap between reed switch and pulley.
Replace the hood.
Plug in the power cord.
Reinsert the key into the console.
Run the treadmill to check for a correct speed reading. This may take a few minutes.
With this you will fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
