You my find the pump is fine , it just got a coin down in the pump. pull the hose off and stick your finger in and clean out the coins. I fix mine this way
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
