Hi Ian, This means the water is not draining out of the dishwasher - probably the filter is clogged. Your dishwasher has a filter fitted in the drain that prevents scraps of food from entering the pipes. Please try to clean the filter, hope this is helpful.
If the problem persists please see more possible reasons here: https://www.repairaid.co.uk/dishwasher-repairs/not-draining/
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
have you cleaned out the water pump and hose ? check drain hose for blockage, check pump wiring to make sure it has a good connection.120 volts to pump. pump or board bad.
OE error is noyhing but an Outlet Error..OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged -
Clean and straighten the drain hose / clean the drain filter. also do check for the pump blockage. for more info on this check the following link http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
