SOURCE: i cant get good distortion out of my fender
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
SOURCE: Everytime I play on my
You don't say if you are using a footswitch or not... If you are, the switch, cables and connectors are suspect.
If you are NOT using the controller, the switch contacts on the footswitch jack in the 212 are suspect as being intermittent contacts.
If the contact is not making, the OD switch on the unit will NOT work either.
These jacks, and their contacts are JUNK and often cause problems.
Open the unit and increse the tension of the contact springs.
