Question about Fisher and Paykel GWL11 Top Load Washer
GWL 11 takes forever to fill with water - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Aug 13, 2011
Anonymous
SOURCE:
Fisher & Paykel GWL-11 Machine very flaky.
may I be frank there seems to be to much going off at any one time that its hard to pinpoint a solution except a new washer eric
Jan 16, 2018 | Washing Machines
Fisher and paykel gwl 11 fill problem,when cycle start its filling up ok but after minute or two starts filling very slow
Check the valve where water inlet hoses attach to back of machine. If you have hard water mineral deposits tend to clog up this valve. You can remove and clean this valve or just replace. GOOD LUCK FRIEND.
Nov 16, 2014 | Washing Machines
As soon as water begins to fill the tube, water exits out the drain pump and drain hose. F/P GWL 11.
Is the drain hose too low? The drain hose needs to be higher than the top of the agitator , then curve over into the outlet pipe or basin.
Oct 25, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
294 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
