LG LHD65EBL Dehumidifier Logo
Posted on Aug 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Dehumidifier Model LHD65EBL ch o1 appears on the screen. can i change the internal thermostat myself? is it a plug in module? if so, where can i buy one?
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Aug 15, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10842495
Points
101584
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
I have an LG LHD65EBL dehumidifier. When I checked on it today the unit was not running and the display read "CH 01". I tried cleaning the filter, cleaning the front of the coils, and resetting the unit by...
Hi
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
1helpful
Need a fan motor for LG dehumidifier model LHD65EBL, can you help?
Contact LG customer service 1-800-243-0000 option 7 for assistance.
2helpful
My dehumidifier just stopped and says CH O1, please help. i cleaned the filter!!!
Did you dump the water out and replace the bucket correctly?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Trouble seting up the LG LHD65EBL
Good morning, Click blue word site for the lg site and put in model number. It came right up.
26helpful
2answers
Ch 01
Change the sensor assembly and all will be fine, about $30 from Appliance Factory Parts on line store, about an hour to do, all that is needed is Phillips screw driver to take unit apart.
1helpful
2answers
LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
