SOURCE: Video playback problem on lumix dmc tz3
First Bob, I believe there is a menu setting that allows you to disable picture/movie deletes as long as it is enabled. Check this out regarding "this picture cannot be deleted" problem.
Second, assuming your screen is ok since you can read a message from it, I would try FORMATing your memory card, after downloading your pics/movs to your computer from the camera. Note to view MOVies from your camera on your computer, Windows Media Player will not play them. You must download Apple's QuickTime Movie Viewer to view .mov file format from panasonic cameras, or use a view that came with the camera on CD.
SOURCE: how do you delete multiple pictures from the
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
SOURCE: panasonic lumix dmc fz18 won't zoom in or out
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
