Microwave Ovens Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After using my microwave oven 3+ minutes it shuts itself off - clock everything goes blank - it acts like it is not getting any electricity. After awhile, a 0 will show up in the display window. Then it will work again. Any ideas? My Maytag microwave oven (Hood) is model MMV1153BAW. I have replaced the fuse thinking it had blown a fuse the first time, but if you wait 30 - 40 minutes, the 0 will display in the window and it will work again without replacing the fuse each time.
Anonymous
Level 3:
  • Master 2,006 Answers
  • Posted on Aug 15, 2011
Anonymous
Master
Level 3:
Answers
2006
Questions
Helped
593190
Points
6261
1helpful
2answers
Why does microwave turn itself off occasionally after a minute or two
There is a fan inside that blows air across the electromagnet that cooks your food. It gets hot! The fan is most likely broken or spinning to slow to keep the electromagnet cool enough. There is a thermal sensor on the electromagnet to shut off the oven if it gets to hot to prevent it from catching on fire or melting everything inside the oven control area.
I have a Whirlpool old model # RM278BXV-3 and it has started shutting all the way down when heating things up. Contol panel goes blank and quits heating.
Sounds like the control panel. All the other parts are just brute force parts and either work or they don't. Over heating components on the control board are the probable cause.
1helpful
Power shuts off periodically
1) this occur to due some connector need tightneting or resoldering in the board.(coolder joint)
2) for repair component you need to remove from kitchen unit.
3) look for another wires connector loose, and see if there are some component burn. and repair.
God bless you
Setting clock on EM-G2567S
1. If you press the 'Delay Start' button, the time display will go blank.
2. Now enter the correct time, using the 'Minutes' buttons to set the hour, and the 'Seconds' buttons to set the minute.
3. Now press 'Clock'
4. Sorted!
4helpful
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
2answers
Microwave shut off
try to checked the fuse if its blown.and replace a new one,check also the power cord.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
