If you disconnect the fuel line from the carburetor, direct it to a container. Then turn the engine over by the ingition switch. If you have good fuel flow, problem is probably in carburetor, if no flow then the fuel pump should be replaced. I was just thinking, if you see fuel coming from the tiny vent holes in the fuel pump, then pump needs replaced cause diaphram is damaged.
I hope this helps you get it going again soon.
