Question about Datamax Office Equipment & Supplies
Printing 2 previous labels before printing current label. Seems like it is queueing 2 labels before it will print the first label, then it is stuck that way forever. Button click -> print, print, get a label. Label is the one you printed before twice. Click print one more time, you get the label you are currently trying to and are looking at.
    Champion:
  • 254 Answers
Check in your configuration that you are not in multiple label mode.
Use single buffer mode
Posted on Aug 16, 2011
6ya staff
SOURCE:
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
Printing two labels at a time instead of one.
im not sure about datamax but on a zebra theres settings for media types like continuous or tear off. maybe thats it?? does it calibrate correctly?
Oct 08, 2017 | Datamax I-4208 Thermal Label Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Label Printing Problems
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Dec 12, 2007 | HP Officejet 4215 All-in-One Color Photo...
628 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
