I recently bought a 19 inch LCD TV --- Generic Chinese, carrying the Lloyds brand name, model LCD1932WB. I want to determine the codes needed to allow me to program my cable box remote control to operate the TV, as it does for other brands already in my house. The automatic set-up does not result in discovering the right code, and this make is not listed in my cable service's web site. An email to the distributor, "Cosmo Communications Service" yielded a confused reply, but included the suggestion that I contact Diamond Vision --- presumably the maker or perhaps main importer. But I'm having no success finding such a company or a site with the codes for my "Lloyds" LCD TV. Can you help?
Lloyd's lcd1932wb - i need info for setting up my universal remote. i dont know which category (tv, cable, vcr or aux) do choose for setting this flat screen and i cant seem to find the code doing a manual search? does anybody know if theres a 4-digit code to program my universal remote? i hav try'd manually searching but i just cant figure this one out?... its frusterating... could someone please help me? thanx
I Have the code that you need, try 627, or 679, if this does NOT work I have a
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Programmable IR
Blaster that I can also use to find codes. Let me know how this works.
Rick
I don't know what happened above but again try 627, 679. If not I have a programmable IR Blaster that I can use to find codes. Rick.
Unable to find codes with Programmable IR Blaster so I have no choice but to use a remote that can " Learn " IR from different remotes and it works great now with one remote. What a pain.
It needs to be a five digit code....???
HI, I have the same problem. A 19in Lloyds TV and trying to hook up digital cable box but do not have the 4 digit code. I tried the 627 and 679 as mentioned above but was not successful. Anyone else have any luck?
I allso bought a lloyd`s lcd1932wb 19 in. tv and I cant program my ge remote control .No listings for lloyds t.v`s.
Thanks, but tried programming either code into my cable box remote, and neither were accepted, and neither would control the TV.
You refer to having a "programmable IR Blaster" --- Is this a hardware device? Or software for a laptop or Palm or other device with an IR port?
Mike
I purchased a 29" TV/DVD combo Lloyd's TV and the remote code was 1903
Another note. I found these codes in the Atlas remote control manual pdf under the Samsung, Akai codes so perhaps Lloyd's is sourcing it's stuff from the same place as Samsung
