Weiser Lock Powerbolt 1000 Lock Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How long should I expect my lock to last? It is app. 3 years old will only lock & unlock app. 3 or 4 times then dies when the batteries are replaced... The batteries still have a full charge.when removed. Is there anything I can do besides replacing the lock?
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Aug 24, 2011
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489367
Points
1500
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Why does my ryobi 18v hybrid string trimmer work well on electric but slowly on battery?
How old is your battery? Don't expect a battery to last longer than a couple of years. Try this before going for another battery. Put the battery in you freezer for 3 days. Take it out and let it thaw for 4 days. Charge it and see if there is any new life in it. If not, it's battery time.
Car Alarm not chirping when turning on/off
Check the battery
They only last 3 to 4 years in some cases
(cars battery)
That will make the chirp if the module voltage is low
Next would be to have the modules checked for codes
& or diagnosed to find a problem
Infiniti G35 wont open
You can not jump a dead battery
That is also an unsafe practice
Have to disconnect any battery that is
dead & try to charge it first or replace,
if it is over 4 to 5 years old & died
5 year old sedona has low mileage completely dead. What is expected life of battery?
There is no set life expectancy
My wifes lincoln dies at 4 years every time
She had a new cadillac that never made 1 year
I never get less than 8 or 9 years out of a battery
35 years running
If you do not buy the most expensive battery,the one with
the most cca rating,& it has to be completely sealed on top,
not look sealed & have caps that don't come off,then 4 to
5 years is about it
3answers
LG Voyager Locked
To enter unlock code for LG, You need to insert sim card from network which is ... You can get Your LG VX10000 Voyager IMEI number by typing *#06# or after ... are locking devices on carriers demand, so when you unlock LG VX10000 ... sim-unlock.net/simlock/LG/VX10000 Voyager/ sim-unlock.net/simlock/LG/VX10000%20Voyager/
hope this helps
Lenovo battery won't charge
Battery not charging usually means its dying! If your battery under one year old, you can get replacement from Lenovo. If its older than three year old, its time to find a new battery!
Is the battery not holding the charge at all? that means is the computer shutting off as soon as taken from power outlet or battery lasting less than expected...
The battery on my 2007 Xterra just died. Is there a possibility of some sort of issue other than the battery being dead? Its only 3 years old.
There are possibilities regarding battery become dead and can't be charge anymore.
The first one would be the battery has a life expectancy of 1.5 years to 2 years.
The battery if less than a year and died, that will be a manufacturers fault, where the battery might have some defects when it was manufactured.
The battery died less than a year can be attributed to overcharging of electricity from your alternator.
Your lucky your battery lasted for 3 years!
Hope that clears up your problem!
Thanks for using Fixya!
Laptop just dies, then will run fine again and die. Is it the battery? only a couple of years old if that.
Yes, the battery has aged. 2 years is the most what you would expect a battery to last so that's normal.
1helpful
Kyocera M410 resets date and time when changing batteries
There are tiny Li batteries to maintain the short term memory for interim period. Normally they last very long but unexpected can be expected. You may not have enough tools to open it & reach there. Either go to camera repair or just entering it everytime or give it to the kids & buy new one instead of repair.. [email protected]
Top Weiser Lock Locks & Locksmithing Experts
Sean Wright
Sean Wright
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
