SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
SOURCE: Connecting a Wii Game System
yes and no - you can unhook one device but the connectors will soon go bad (connections on the board) - better idea is to hook the wii in the the vcr and put the vcr on input 1
SOURCE: Problem with RCA HDLP50W151
Press power and channel down at the same time to do a soft reset
this should fix it if its a software glitch
thanks
scott
SOURCE: Direct TV Hookup
please help my remote has change language and jumping chanel and pause on mute
USE a VCR between the PS2 and the Sylvania TV. Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4. Set the VCR channel to Line 1 or Line 2. This should work. I hope it helps you.
