SOURCE: kenstar split airconditioner display E6 error what does this mean
Kenstar is displaying F8 error
SOURCE: not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
SOURCE: Where is the filter located on a R-410A Split System Air Conditio
Hi!!
The filter is located on the outside unit, Near the compressor.
Don't forget to rate this post!!
Testimonial: "Thank you. You were very helpful, I give you an A+"
SOURCE: senville mini split codes
Put gage on low side and check the pressure running. if it is less than 125 you probably have a leak.
