SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
SOURCE: hp laserjet 1320 printing blank pages
Hi, If you have replaced the toner acrtridge and still the printer is printing blank pages than it please make sure you have removed the maler strip of the toner cartridge if yes than perform engine test page of the printer wherein remove the side panel and there is a small button to press and it print engine test page and that will bypass the formatter if the engine test page is also blanik than it is the issue with transfer roller (Which create the image) Power Supply( Create image on transfer roller) or Laser/Scanner assmbly which creates the laser image on transfer and all these three parts are not customer replacable(Hardware Issue) and customer need to get the printer repaired by HP Authorised Engineer.
SOURCE: How do I replace fuser on an HP Laserjet 1320?
call hp they will walk you thro it or go online and do instant messanger tech support chat on the hp website
