When you push the power button, the blower fan comes on. In a few
minutes you should hear a second "click"--that is your compressor
starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
I have the exact same issue word for word! I looked everything over and the only thing I found was the air filter was dirty and needed cleaned. Still did not work.
I have just encountered the same problem on my unit. The LCD show 01% humidity, the bucket full red light blinks every two to three seconds, The Up/Down setting does not change the LCD. Machine does not start.
Kenmore 54501. Got the same exact problem as well. Talked to Sears Parts and the main brain of this is the "PWB (PCB) Assembly Main" which the CSR says what most people order for this problem. It costs $12 and thinking it is worth a try. Anyone tried fixing this by replacing this part?
I have this problem does anyone know the answer?
