i ALSO HAVE A BROKEN SOON BUTTON FROM EXCESSIVE USE, TO KEEP IT RIGHT I MUST KEEP MY FINGER ON IT OTHERWISE IT GOES BACK TO NORMAL.i ALSO HAVE A BROKEN SOON BUTTON FROM EXCESSIVE USE, TO KEEP IT RIGHT I MUST KEEP MY FINGER ON IT OTHERWISE IT GOES BACK TO NORMAL.
You can't post conmments that contain an email address.
helow, can you please explain the problem
if you meant zooming doesn't work, it can be due to
zoom button broken or zoom mechanical problem
if you hear any weird sounds when you try to zoom that maybe to broken gears or a dislocation of the gears, you need to take it to a repair center
hello there! lg gt505 does have a zoom function. but if your using 5mp image size you will not be able to zoom your camera. you can only zoom if you change your image size to 3mp and below. you can zoom further if change to 1mp though. hope this helps. happy taking photo! =)
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
Depth
2.1 in.
Film Type
35mm
Width
4.6 in.
Height
2.5 in.
UPC
018208018789
Battery Type
1 x 3V Lithium Battery (CR-2)
Weight
7.84 oz.
Self Timer
Yes
Camera Type
Point and Shoot
Focus Type
Autofocus
Minimum Focus Distance
1 ft.
ISO Range - Automatic Setting
ISO 100 - 800
Red Eye Reduction
With Red Eye Reduction
Zoom Size
2.4
Auto Exposure
Yes
Min Aperture
f10.5
Waterproof
No
Max Aperture
f4.8
Zoom Lens
With Zoom Lens
Zoom Range
38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera. You can replace upper part of camera with following part number.. A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part. Part available in Parts Store for $24
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
well did the camera got wet???, if soo it needs the mainboard to be replaced, if not could just be the mainboard also, but if it´s the second one the repair centre will fix it for free if ?t´s under warranty
