Zebra Z4Mplus Label Printer Logo
Posted on Aug 17, 2011
I am using a Z4mplus printer to print a pdf label of size 4x6, when printing, the label prints bigger than the pdf size and we cannot figure out why. When printing the document and paper size both says 4x6. Any idea of what could be happening will be appreciated. Thanks.
  • carina_perdo Aug 19, 2011
    This is the first time using FixYa, what it means to see "clarification request"? Thanks.
2 Related Answers
Anonymous
  • Posted on Feb 11, 2011
SOURCE: Zebra Printer / SQL Reporting Services print problem.
Any joy on this, we have the same problems.
frank_yd
FDFDFD
  • Posted on Sep 10, 2014
Same issue, please help!
Zebra Eltron 2844 is not printing 4x6 shipping labels. I am using the printer to print FedEx labels. i recently had to reinstall the driver, and now when I print, it prints just under 2x4, rather than the...
You can recalibrate it to read the label size by doing the following.
Power off the printer
Hold down the green button
Turn the printer on and about 1/2 second after turning it on, release the green button
It will print out some information and measure the label. Once it stops, hit the green button one last time and then try to print another label.
Label prints at the buttom
check if seting from LABEL TOP is on 0000, check the driver as well.
2answers
2answers
Unable to print a 4X 6 label
asslam aleekum wr wb
mere pass zebra printer hina but us mian ak problem ya arha hian k us k print out blank arhha hian why?
plz mujhe batey
2answers
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Label size
Set the label size in the label program and then calibrate the printer.
Z4Mplus doesn't save configuration
I had the same issue.
I'm using the seagull scientific drivers.
It turns out that the printer did not react well to changes made to it through the software.
I deleted the printer and added it again.
I made all my changes immediately through the software (creating a custom label size of 4in x 1in and portrait 180)
My print width setting on the printer is still 099 6/8 but everything prints fine.
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
