Hi
You can login to the router setup by typing http://192.168.0.1on the address bar of Internet Explorer
Make sure you do it on a computer that is connected to the router with a Cable
Then enter the default password (admin) lo log in to router settings
On the left side Click Wireless Settings
Here you can see
Wi Fi Protected Setup Also known as WCN in Windows Vista
Disable it
The Next section Will be Wireless Settings , you can find the name of your wireless network here
Change it to a different name
Make Sure the Visibility Status is set to VISIBLE
On the next section you can find the Wireless Security Mode
Make it as WPA - Personal
Then Choose the WPA Mode As WPA Only
The Cipher Type should be TKIP and AES
and the Group Key Update interval should be 3600 Seconds
Then in the Pre Shared Key box ,
Type A Password
It Should be Minimum 8 Characters
Make Sure you remember the New Name and the Password
Click Save Settings at the top
Now the Network is ready
Try to lookup this network on the Ipad
Connect
When prompts for password
enter the new Password
Let Me Know if it works
Regards
TOM
