Check if you MIGHT be in a "guide" or learning mode. Some Yamaha synths have a mode that will play and then wait for you to hit the right key before moving on. If this is not the problem, a fix is not DIY and will require repair. I assume you are NOT using MIDI as in that case it is called "dreaded MIDI drone" and is due to data looping back into the unit which is an external fault.
