No, no breaker. It may simply be the case of the water collection bucket is not installed properly. When that happens, nothing will work. Remove the bucket and check the top of the inside of the bucket for a float valve (if yours is so equipped). It may be stuck in the 'UP' position, which makes the unit think the bucket is full & everything turns OFF. If you see one, and the float valve is UP, jiggle the arm of the float valve to get it to return to the DOWN position.
Whether your unit has a float valve or not, when you reinstall the bucket, be sure to install it "squarely" from top to bottom, so that it makes firm contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly, the bottom of the bucket should not tilt down at all.
If none of the above solved solved the problem,it may be an electrical issue. The circuit breaker for the outlet it's plugged into may have tripped. Check your home's circuit breaker panel for a tripped breaker. If you find one, unplug the dehumidifier before resetting the circuit breaker. Also, the wall outlet may be damaged or have a loose wiring connection.
All of the above are things that you should troubleshoot first. It's a process of elimination to determine what is causing the problem.
I hope this has helped to get you started on solving the problem. Thanks for choosing FixYa.
