SOURCE: mic input
have seen a couple of these cameras with this problem. a defective board inside the camera is the culprit. the board itself costs around $500 plus the labor to replace it.
SOURCE: M-Audio USB
U need an external phantom power supply, they run about $19.99, or you can get a different interface which has phantom power onboard, the cheapest one would be the m-audio mobile pre usb but that would not work on vista 64 bit... best bet is to get external power....
SOURCE: I recently purchased a samson
It seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
SOURCE: using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
