Question about Apple iPhone 3G
IPhone 3G passcode forgotten? anyways? - Apple iPhone 3G
  • mitchel starc
    mitchel starc Dec 06, 2018
    As we know that iphone security is more secure than android. if you have forgot the passwordhttps://www.uaetechnician.com/asus-lapto... helped me to get the new password. who can help you resolve this issue over the phone in a minute or two.
  • Dj Bravo
    Dj Bravo Dec 02, 2019
    Iphone 3G passcode is forget you have to reset your phone to access. Its for something for data privacy.https://www.europewebsitedevelopment.com... follow these steps to get passcode.
    New Friend:
  • 3 Answers
Your iphone 3g is avelebale plice request is castmare care the 3g satting on your hensets ok. Thanks you
Posted on Aug 18, 2011
  • 1,140 Answers
You can unlock your forgotten phone password by downloading this free software,no need going to apple shop and paying the service.
IPHONE PASSWORD REMOVER
Be sure you have a good working USB cable
Here's the instruction
* download the link above
* locate the file (usually on download folder) and extract the file
* run the program,instruction is already given on screen so you don't have to worry on the procedure.
* reboot your phone
* DONE
Hope this solution helps...Thank you for visiting Fixya...
6ya staff
SOURCE:
Tip
Recover from a Forgotten iPhone or iPod Touch Passcode
If you have forgotten your passcode on your iPhone or iPod Touch, you will need to do a restore in iTunes, but you must first put the phone in "restore mode." However, when you do a forced restore on iphone, you will wipe all content from the iphone, there is no other way around this. To put the phone in restore mode, hold the HOME button while the phone or ipod is off. Then, connect it to the USB cable and continue holding for a LONG time (or as long as it takes until you see a screen with a cable and the itunes logo). Once iTunes responds that it sees a connection in recovery mode, click restore and it will reload the phone/ipod to factory settings, and will be free of the forgotten password.
on Apr 03, 2010 | Apple iPhone 3G
Ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
I have forgotten my passcode on iphone 3gs
Hello Dass,
Press and hold down the Sleep/Wake button and Home button simultaneously for at least 10 seconds; the screen will clear out and then the Apple logo will appear on the black background. When the logo appears it means that reset is done.
May 31, 2011 | Apple iPhone 3G
I can not rember my id password
If you have lost your iTunes password you can reset it here: https://iforgot.apple.com/
If you have forgotten your passcode on your iPhone you have to restore it to factory settings
Mar 04, 2011 | Apple iPhone 3G
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
I have forgotten my passcode on my ipod, how can i remove it ?
follow this instruction.
but you must understand that if you do that all contents of your iPhone will be removed, including the passcode and including the jailbreak if your iPhone is jailbroken. the software will be as good as brand new.
good luck.
for more iPhone / iPod touch tips, click here.
Feb 15, 2010 | Apple iPhone 3G
I forgot the password for my iphone
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Dec 11, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
225 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
