Televison & Video Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A verticle line in the picture "Top Down Dead
Allen Bennett
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Aug 18, 2011
Allen Bennett
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
16286
Points
94
You may have a bad CCFL Backlight lamp in the LCD Panel. To check it you will have to take the LCD pandel apart to see it.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
0
Helped
44947
Points
825
The symptom of your television is vertical problem.The problem is in vertical section of the board.Maybe theres a leak capacitor in vertical section.So try to replace the leak capacitor,the value is 100mf 35 v.You can identify the leak capacitor through visual checking if you have no knowledge in using tester to identify the leak capacitor.If you can see the capacitor have rounded shape at the top while the good capacitor is flated shape.
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
RCA F27351WN
the verticle is over amplifying, check the capacitors around that stage.
check if on your verticle you have a pre set to reduce the voltage going to the scan coil.
if you cant do it take that set to a w/shop.
1helpful
ORANGE OR RED VERTICLE LINE DOWN RIGHT SIDE OF SCREEN?
hi..the probelm is due to the video circuit board.
only when you have a problem with the video
circuit board you will get such type of faults.so
you have to check the video board immediately.
check it out..
thank u..
rate me..
Pink pictures with lines
cannot transfer pictures from the camara to my laptop,i also see lines on the pictures after taking the pictures
1helpful
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
1helpful
HP PE4240N Lines in picture
go to this link and read carefully!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Vertical black line
does this verticl line go all the way form top to bottom or is it about 5-7 in long in the center of the screen and does it some times change in color with the picture.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
