SOURCE: Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
SOURCE: how can i access to a sony bravia kdl-26m4000
With the remote and TV off, press these buttons in order DISPLAY, 5, VOL-, POWER. Be careful!!!
SOURCE: Sony kdl-26m4000 LCD TV. While
The processor of the tv locks up because it suddenly becomes incapable of correctly processing the signal data - it crashes.
Since this is an intermittent problem that appears when a big spike in power is required from the source that means that the problem is caused by a dip in the voltage powering the processor - the power source has aged and it's no longer capable of delivering a steady supply.
You must open the tv, locate the power source and refurbish it: start by replacing all capacitors, then check the rectifiers, then the zenner diodes and finally the stabilizers.
SOURCE: sony kdl-46s4100 picture goes off
Does tv lose picture in all tv channels?
Did you checked tv picture by playing back dvd player?
Is tv connected with cable box, if yes, is it HDMI connection setup?
Let me know above info to diagnose cause of problem.
Thanks.
