SOURCE: lost installation disk for canon pixma iP 1500 inkjet printer
Go here, select your model from the drop down menu and then on the next page, select your OS and install.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
SOURCE: will iP-tool.exe v.1.1.5 reset my iP2600 ink levels to 100%
Yes it does reset ink levelsas well as do several other things very well.....highly recomend the program for an ip2600
SOURCE: how to install canon printer MP140 without a disk
You can download the drivers and software for your printer from CANON:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15294
Click on the "Drivers and Downloads" tab and then select you OS.
SOURCE: I HAVE A PIXMA ip2600 canon printer need win me softwear to run
It says that this printer is not supported on windows 98, but they do list a driver and software package at the following link. You might want to try it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=16278
I hope this helps, Good luck.
SOURCE: Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
