To start with, you have a throttle body instead of a carburetor. On that throttle body is a component called an air control valve. That valve is how the computer controls the idle speed. It should open and close the air flow into the intake manifold as needed. Is the check engine light on when you are driving ? Have you checked the fuel pressure ?
usually if you run your car or truck dry it messes with the fuel pump really badly so i would check your fuel pressure. not sure what kind of car or truck you have but its really easy to look up how to check your fuel pressure on the internet. its also a good idea to put an additive in with your next fill up just to lube everything back up. oil only lubes the one side and a lot of people dont know that additives really save your engine some stress
does the car have gas check fuel pressure change plugs wires change fuel filter change air filter change throttle postion sensor is you check engine light on
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
I saw this once where a guy took his car to one of those Quick Oilchange places and the kid put in new oil and forgot to take the old out first. Another thing to check is youre PCV Valve, if this is blocked it will increase your crank case pressure.
clean the carb's insides. It's probably gooped up with gummy gas. I like B-12 Chem Tool. Its a spray cleaner from Auto Zone about $4. Others kinds are ok but this is good stuff.
