Question about Itochu C.itoh CI 5000 Matrix Printer
C.ITOH CI5000 printer will not print in condensed mode.
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 93 Answers
SOURCE: SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
Posted on May 19, 2009
Anonymous
  • 51 Answers
SOURCE: p5010 line printer, I want to print in condensed mode
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
Posted on Jan 01, 2009
Epson TMU-295 prints in condensed mode with Windows 7 from web application while the same printer prints the same output in normal mode with Windows XP. How comes?
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
Aug 11, 2011 | Epson TM-U295 Matrix Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Looking for a manual for a C.Itoh printer mod# c310
hi there, if you go to the printer manufactures web site, it is highly likely that you will find a PDF version of your manual for your printer.
Jan 20, 2010 | Office Equipment & Supplies
Printer head damage the printer ribbon
See if there is a pin sticking out of the print head. If so, you must replace the head. You can google and find a head.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 04, 2009 | Itochu C.itoh CI 5000 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
hi
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
P5010 line printer, I want to print in condensed mode
Jan 01, 2009 | Printronix P5010 Matrix Printer
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Home Error
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
74 people viewed this question
Top Itochu Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
