Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
Nikon Nikkor 18-55mm, The lens feels stripped. How do I fix that
    New Friend:
The Nikon Lens 18-55 wide angel inner lens loosens locks lens no picture
Posted on May 11, 2013
6ya staff
SOURCE:
MIke
  • 685 Answers
SOURCE: nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
Posted on Nov 21, 2009
Anonymous
SOURCE: My Nikkor 18-55mm lens is jammed and inside there
Hi. I have this same problem. Have you managed to fix it yet? I've been told that it would cost £100 to fix it, plus a charge of £20 to send it away.
Posted on Jan 26, 2010
Anonymous
  • 18 Answers
SOURCE: I have a Nikon 18-55mm lens. There is a plastic piece loose.
throw it away
Posted on Apr 29, 2010
  • 102366 Answers
SOURCE: On a new Nikon 18-55mm
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Posted on Aug 30, 2010
akangpepen
Steven Pepen
  • 133 Answers
SOURCE: My Nikon Nikkor 18-55mm lens will not
hi there,
the motor inside your lens might have been broken,
was it fell down or hit something before?
if it`s still in warranty, you can claim it to Nikon Service Center
hope this post will help
Posted on Jan 06, 2011
My AF-S NIKKOR 70-300 1:4.5-5.6 G lens will not focus properly. The focus keeps jumping in and out and the motor has gotten noisy. I checked all function controls to ensure nothing got knocked out of...
Your lens is a cheaply-built kit lens intended to be sold as part of an initial body and lens kit.
It's not built badly or with especially poor quality materials, but it's certainly not to the same standard as their non-kit lens offerings and so is not as long-lasting or robust as regular Nikon lenses.
In your case, the focus drive mechanism has broken, possibly due to one of more motor pinion teeth being stripped. If the lens has not been dropped or otherwise misused and is still under warranty then return it to a Nikon service centre for a free repair. If outside of the warranty, then in most countries Nikon offer fixed price repairs, but you'll find it more economical to simply buy a replacement lens. What's failed is not suited to a DIY repair
You can commonly buy new ex-display examples and definitely fully-functional used examples of your lens for a less than the typical fixed repair price. As you don't state which country/stat you live in, I'm unable to provide example prices.
Jun 27, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Hi..the wedges (black color fibre made) on my 18-105mm nikkor lens broke. Upon mounting the lens on to the camera ,the lens will not latch on. Can anyone suggest any workaround to fix it or getting a new...
The lens mount can be replaced. Any qualified repair shop can do the job or, if you feel confident, you can do it yourself. One source for the required part is here.
Feb 08, 2011 | Nikon AFS DX Nikkor 18105mm f3556G ED VR...
My Nikon Nikkor 18-55mm lens will not automatically focus even when set to "A". I have cleaned it with canned air and the manual focus works fine. I want to repair it myself as Nikon has quoted...
hi there,
Jan 05, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I used the Nikon D90 with Lens Kit 18-200 mm, and I also bought the new Lens call Nikkor 75-300mm. But when I connected the new one (Nikkor 75-300 mm) in my camera and took some pictures, after that I...
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
Dec 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nov 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 18 to 55 lens wont focus
Nov 12, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
147 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
