Have you already connected both power jacks to your board? It's motherboard needs two supply of power. One is near the cpu fan and the other is at the right side end. Check also if the power supply has the same value as your power outlet. Low voltage can still cause this king of problem. 220 Volts - 220 Volts, 110 Volts - 110 Volts. Hope this could help a little friend. Have a nice day.
Have you checked your monitor first to other computers try to connect your computer monitor to a friends working computer and see if it is working. One or two motherboards can be defective, but the third one, tat taa, thats imposible. Just try if your computer monitor works before doing anything else. That is the last piece we didn't check yet. Keep in touch for analyzing that can be time consuming, but i'm willing to help you as far as i can. Good day keep in touch, i'll wait forthe outcome.
monitor works fine. The problem is that i press the switch-on button and nothing happens (no leds, no fans, nothing on screen)
I tried to clear nvram with switch 6 on and without the mobo battery, but didnt work.
its unbelievable but i have 3 from 7 ml350 kaput. all broke this year. The next will be a real problem because i dont have a replacement.
I think that they a reaching their live expectancy, or im doing something very obvious wrong, but itsnt the monitor ;-D
thx 4 ur attention, I appreciate it.
I plug the 2 connectors from the top of my mobo, with 24 and 20 holes, to the backplane.
I insert a powersupply in the backplane.
I connect the frontal buttons panel to the mobo
I conect the system fan to the mobo
I put 1 ram and 1 processor with heatsink on the mobo
The mobo is outside the chassis on the table, connected to a monitor
nothing more is connected; the hd controller card is out.
I think this configuration must be enough for a "good" mobo to start post something on screen.
I dont see the power jack at the right side end. All backplanes ands powersupplys are 220Volt
Im afraid that i must bury the 3 mobos :-(
anyway, thx for ur answer!
