Question about Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera
My Panasonic Lumix FS10 wont take any pictures, (the memory card is write protected) is displayed on the screen?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 21, 2011
6ya staff
SOURCE:
Panasonic Lumix DMC-FS10 Digital Drivers
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 12, 2014 | Panasonic Lumix DMC-FX3 Digital Camera
I have Panasonic DMC-ZS6 Lumix w/4gb memory card - has worked fine until today- now window says
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
My camera says memory card protected how do i take this off
Eject memory card and flip the white switch. If that doesn't fix problem some cameras can add accidental deletion protection which first needs to be disabled
Jun 07, 2012 | Panasonic Lumix DMC-G1 12.1MP Digital...
Sign comes up when screen turned on to say memory card is protected and wont go away. while this sign is on camera cant be used
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Hi i have a Panasonic Lumix DMC-FZ8. How do I
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
Jun 17, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Memory card is locked
Make sure taht the write protect notche of the device found on the side part of the card is on.
Alex
Jul 18, 2009 | Panasonic Lumix DMC-LC20 Digital Camera
How to unprotect the memory card
Memory card has a slider switch which prevents write access. Move switch to other position.
May 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera Logo
185 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
