First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard drive utility screen. The key command differs depending on the modelToshiba computer that you own. Select "Restore Original Factory Image" from the list of options in System Recovery.18 Aug 2017
Satellite 1800-S207 Windows 7 and earlier Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden image, you can restore your computer to its factory-fresh software condition. How To: Perform system recovery - Windows 7
The following article will show you how to perform a system recovery. To Recover or perform a system recovery means to take the laptop back to factory settings (default settings). System restore means to go back to an earlier point in time on the computer.
There are two methods to perform a system recovery:
Restore Toshiba to Out of the Box Condition If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the system recovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1.Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2.Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3.Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4.Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5.Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6.Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
If my answer has helped you today please offer four thumbs up as thanks!
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
start > all programs > accessories > system tools > system restore, restore it to the first point, and though this will erase all your files prior to, it will roll back your computer back to the original settings... also going to computer info, you can reset the settings to the default...
if it is running go to start and then programs//accessories// system tools // system restore if it not running hold down the f 8 key and in the advanced screen all you will be able to do is set it to the last cood configuraton if you are talking about totally restoring it back to the factory settings you will need your restore disk ok best regards mike
