EA Sports FIFA Soccer 2008 for Windows Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whenever any match starts, the graphics goes haywire. Screen is strange combination of black and red and yellow and other strange colours. Windows Xp sp2 2.93GHz 1.93 gb ram
Rhythm Gandhi
Level 2:
  • Expert 94 Answers
  • Posted on Nov 14, 2011
Rhythm Gandhi
Expert
Level 2:
Answers
94
Questions
Helped
39252
Points
202
If you don't have a graphic card then try lowering down your graphics..
If you have it check whether it's damaged or not or simply an update may fix it.
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
RED COLOUR ALL OVER SCREEN
this sounds like a problem with either the screen or, more likely, the graphics chip. If you can't replace the graphics chip (if it's not on a separate removable card), I'm afraid you'll need to bin it and buy a new machine.
The acer logo is displayed before the graphics drivers or windows has started.
2helpful
2answers
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
I need the color codes for a 2001 ford explorer sport.Im trying to install a sony explode CDX-GTO9
if you have a ford "amp fitted" you may have prob if not
the power feeds go to 1 block
get a test lamp and find the
switched live = goes to red
constent live = goes to yellow
ground earth = goes to black
speakers and dash display to 2nd block
spearker leads are matched in coloured pairs , use 9v battery to each pair to track speaker location, will buzz when hooked up to matched pair
Where can I find the colour code for the wiring of a radio in a 2001 ford transit
speaker leads are matched in coloured pairs , use 9v battery to each pair to track speaker location, will buzz when hooked up to matched pair
1helpful
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
COLOURS PRINTED DO NOT MATCH SCREEN COLOURS OF ITEMS
I would try cleaning off the nozles on your print cartridges. If that doesn't help, replace them altogether.
2helpful
2answers
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Top EA Sports Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
