Panasonic Toughbook CF-73 Notebook Logo
Posted on Aug 20, 2011
Driver: audio, video,modem, SMK PnP TABLET - Panasonic Toughbook CF-73 Notebook
The type of audio power and the number on onkyo A917 amplifier
Hi
Usually there are 2 transistors for each channel, if you don't know the numbers on the transistors.
there is another way to get as close as possible to have equal or similar to the same type of transistors (NPN/PNP)
example: 2SA is PNP transistor.
there are (2SA/2SC) transistors and there are (2SB/2SD)
complementary transistors
1: you have to know the supply voltage for the transistors
2: choose transistors that it is equal to the current and voltage that suits the supply voltage.
follow this link to find suitable transistors.
be aware and be careful that there other parts you need to check on the power amplifier circuit, resistors,capacitors and drivers etc...
I would suggest (2SD1047/2SB817)
http://www.smcelectronics.com/DOWNLOADS/COMPTRANS.PDF
Good luck
Hope this helps
Crystalview xt manual
I cannot say for certain; however, several reasons cause this to happen. One is Old communication drivers need to be replaced with updated versions. Distance can be factor; how far from the source (Modem or WiFi sender) to the tablet? Then there is hardware factor> some internal Wi-Fi receivers inside of the tablets start to weaken over time and die completely sometime down the road. The final factor can be damage to the sensitive electronic parts and circuit board. If a tablet has been dropped or misused; the tiny and thin mainboard could fracture. Cold and/or heat could open a vital connection and if the board has a separation point, the opening (called a SHORT) will disconnect a portion of Audio, Video, or Communication sections. Your problem has a variety of possibilities which require actual inspection of the Tablet by a Technician.
2answers
There is no sound on my laptop And i lost the driver cd pls help
Clarify me please your laptop's brand / model and your Op. System (windows XP, windows Vista, windows 7) to guide you to download and install the drivers.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I need to load the drivers for the audio and video on my Sager D270s. It's a windows xp and the pnp for the video and audio are below Multimedia Audio Controller PCI\VEN_1039&DEV_7012&SUBSYS...
Connect the system the internet, click your start menu, scroll to control panel and click it. From your control panel, double click system icon, when it opens, click hardware and thereafter, click device manager.
You would see a list of your hardware, scroll to audio, right click on it and press drivers update. The audio driver will automatically be installed from the internet. The same applies to the VGA.
Make sure the internet connection is strong enough to download the drivers, it might not download if internet speed is slow.
Best wishes.
3helpful
2answers
Please let me know from where i can download the following drivers for my Compaq Presario v2000 machine: 1. Multimedia Audio Controller 2. Network Controller 3. PCI Modem 4. Video Controller 5. Video...
I want drivers for multimedia audio controller and pci modem.Multimedia Audio Controller
3. PCI Modem
4. Video Controller
5. Video Controller (VGA Compatible)
Missing drivers for compaq presario v2000 machine
www.hp.com would be a good starting point. Compaq is manufatured by HP. There should be a support/downloads page on the website
Accidently uninstalled sound device driver - but restore was turned off
Go to Computer>Properties and go into Device Manager. Under Sound, Video and Game Controllers, you will see your device listed with a Question Mark next to it, see if you can right-click and check for Driver Software. If it is Conexant AC97 or Conexant HD, you can easily download the installer from various sites.
2answers
Pb20 and Windows vista
i have the same problem and i have the software and it says its not compatible
MODEM DRIVERS
I DO NOT KNOW IF THIS WILL HELP BUT I WILL GIVE YOU ALL THE INFO I GOT OFF MY PC ABOUT THE MODEM
MANUFACTUER - CIRRUS LOGIC
CIRRUS LOGIC 33600 bps PnP V34
DRIVER VERSION 5.1.2535.0
IM SORRY BUT THAT IS ALL I CAN GIVE YOU
THANKS
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
