Panasonic LUMIX DMCZS7  DMCTZ10 Digital Camera Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a lumix dmc-zs7 with a system error: focus message coming up. seems to be a common problem with these camera's.. how do i fix it?
Anonymous
Level 3:
  • Panasonic Master 43,501 Answers
  • Posted on Aug 24, 2011
Anonymous
Panasonic Master
Level 3:
Answers
43501
Questions
0
Helped
10842507
Points
101584
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Remove front cover Lumix dmc-zs7
This camera doesn,t had a front cover at all maybe the lens has a cover.Just turn it on and the lens open automatically
tip
After reading SteveGorak's experience, I placed the vacuum end of my...
Hello
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
Andrea
on Sep 06, 2011 • Cameras
My Panasonic TZ25 says "System Error - Focus". What should I do?
Panasonic DMC TZ25 compact camera - System Error (Focus)
- Try holding the shutter button while switching on the camera (suggested by Andrea Lock, above). I actually had to try this several times as camera was refusing to reset properly, but after a few goes, lens retracted and camera began to work again. Thanks Andrea.
2helpful
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
I have Panasonic digital camera DMC-LC80. When I turn on camera, it turns off, and on display write "please turn off and on the camera again". I do it, but on display this write again and...
Mine does exactly the same - still holds all it's stored photos but seems to struggle to focus when turned on, then gives up & comes up with the 'turn camera off' message. Get the feeling it's something to do with whatever makes the camera focus.
My huband bought the Lumix DMC-ZS7 camera for me to take to my son's wedding. I never even got a chance to register the camera. I am ready to download the images to my mac computer and have found out...
You can purchase the cable from here.
http://cgi.ebay.com/NEW-USB-Cable-Panasonic-Lumix-DMC-ZS7-Camera-14p-/160533669033
As for the disc, please tell me what you are looking for(a user manual, software that you got with the cam etc.,) so that I can link you to the same on the Panasonic website
1helpful
3answers
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
