Compaq (158165-001) DVD Drive Logo
Posted on Aug 20, 2011
No how i can get nero smart for my compaq 610 asus dvd writer i m using window7
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Aug 20, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
4840
Points
49
Nero 9 is a free burning utility available through the Nero software company that allows users to burn audio and video files to blank CDs and DVDs.
Just search 'Nero 9 download' on google.
The dvd driver of my compaq 610 is not working.whenever i insert a cd or dvd
Spend $35 to $40 to buy a new CD/DVD reader/writer, to replace the "broken" unit.
1helpful
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
ASUS P4P800 SE DVD WRITER NOT WORK
Turn the burn rate down.If that does not solve the problem.reinstall the burn program.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
My computer
you may be using cdrom please install dvd writer and use nero smart software if not installed then install
2helpful
5answers
To get nero burner
You get all legal downloads for nero clicking here: Download Nero.
Illegal and pirate software is not allowed on Fixya.
1helpful
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
19helpful
8answers
Serial number for nero 7
i downloaded the nero 8 trail version from the net but it needs a serial key to activate please send me the serial key for the activation and aslo tell me how can i crack it to make it full version
Dvd writer vs nero
i fixxed the problem when i saw it was not installing lite scribe with nero thanks for your help.
Software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
